bartun
Hello, I want to explain my actual situation with my Mazda 3 MPS Gen1 (European Mazdaspeed3).
Like 4 months ago, I saw my car smoking on cold (finally was just condensation), but because of that, I saw the afr idling was between 14.3 and 14.4 so I recorded a few logs, there we can see a 3rd gear WOT log and idling log:
#LOG 3RD GEAR WOT: https://datazap.me/u/bartun/idle-first-4-gears-normal-use-and-3rd-gear-wot?log=1&data=7
#LOG IDLING: https://datazap.me/u/bartun/idle-first-4-gears-normal-use-and-3rd-gear-wot?log=2&data=3-7
I was runing a Cobb intake, autotech hpfp, catless dp, catless tp, bigger tmic, one step colder spark plugs and a custom tune (Versatuner) that always work'd good.
In the logs, absolute load is low, desired afr is wrong, actual afr is lean, ignition timing is high, boost pressure is very low, and wastegate duty cycle is stuck at 60.3%, basically everything was working bad.
I installed the stock intake airbox, installed stock testpipe and loaded "High flow versatuner map", supposedly its like stock map for stock airbox, but I can keep my catless downpipe installed without getting error and fuel cuts. (THIS IS THE MAF CALIBRATION OF THAT "STOCK TUNE" https://i.ibb.co/1mLzPpS/maf-cal.jpg < Is this the MAF calibration for the stock airbox?)
After a nearly 40km's of all type of drivings, with the stock intake, stock testpipe and "stock map", I recorded log again.
#LOG 3RD GEAR WOT: https://datazap.me/u/bartun/log-1629046533?log=0&data=6
#LOG IDLING: https://datazap.me/u/bartun/log-1629046533?log=2&data=6
Wot values looks good to me I think, but LTFT is maxing at -8.6. If you see the idling log, now the big problem is the afr idling is oscillating so much, normally between 14.3 and 15.0.
After 2 or 3 days more of using the car, I made a few logs more (Now, LTFT is maxing at -12.6):
#LOG IDLING: https://datazap.me/u/bartun/turn-small-accel-idle-3k-constant?log=0&data=6-12
After 2 or 3 days more of using the car, I made a few logs more (Now, LTFT is maxing at -14.8):
#LOG CRUISING 2ND + 3RD GEAR: https://datazap.me/u/bartun/3-logs-cold-small-throttle-low-rpm?log=2&data=7-13
At this moment I have 2 problems, LTFT very negative, and very oscilating afr idling, between 14.3 and 15.0.
After the last log, I cleaned the first O2 sensor connectors + connectors coming from ECU and the ECU conectors + the wiring connectors to ECU with 0 residual cleaner, let them dry, started the car and magically, the afr idling was PERFECT, between 14.67/14.70/14.73
I used the car 3 or 4 days and I think It was solved, but after 4 days using it, CEL P2188 System rich at idle, that means LTFT were over -25%, and car started to give small jerks / pulls at low rpm, P2188 disappeared after 2 days of use.
1 or 2 days later, appeared new error code, High Voltage in second O2 Sensor, and idling afr was again stuck near 14.5
Yesterday, I installed new second O2 sensor, I reseted the ECU and fuel trims, and I tested it.
New Second O2 Sensor Denso installed yesterday.
New First O2 Sensor NTK installed 2000 km's ago.
New Denso MAF Sensor installed 2000 km's ago.
Is my ECU broken? Are my ECU wiring pins / connectors broken? Why my car is crazy? Should I burn my car and turn the page? I am fucking tired.
PD: since all this started, I feel like my brake pedal is very spongy and I have to use a lot of force to brake, It could be because vacuum leak but I read vacuum leak would make possitive fuel trims, not negative.
