This fucking sucks
Try putting the lines onto the master off the car and keep them loose so they can wobble a bit.
It sucks you're having this much trouble. They do make brake fitting taps you could try but if the lines go into the old one then maybe the new one was already damaged before you worked on it.
Then do the same at the ABS module
A stiff pedal won't be caused by a loose bleeder valve. You could have a bound up brake pedal, broken hose to the brake booster, something keeping the master cylinder locked, a stuck caliper.
Is the brake booster adjustable? Some brake boosters are able to adjust push rod length and require a certain spec.
If the pushrod is loose and there is no adjustment at the booster then it is possible it is a faulty booster.
Another area to look for adjustment is if there are threads at the brake pedal where it connects to the rear section of the booster pushrod.
