Woodzms3
Turbo could could be unaffected in performance by the seals. In fact, you can have a turbo with no shaft play and bad seals. That being said, the main reason they fail is due to an unhealthy PCV system. Have you replaced your PCV valve?
Unfortunately you can never be 100% certain on the cause. But your symptoms and historical problems with these cars are all pointing to a very likely candidate.
Yes I changed the pcv valve when the problem occurred and also upgraded the injector seals because i thought my injectors seals were the cause of the issue. But your answers make alot of sense with how my car is running like how u mentioned excessive crank case pressure. When i put the old oem cat (which was clogged with dirt and who knows what) and started it for the first time my theory is that the bad cat caused to much pressure in the turbo and made the seals go to shit after that there was oil in my intake and the smoke started showing up. So guess its time for a new turbo, honestly dont know what else it could be.
