I recently got a set of kicker CSS68 and CSC68 speakers to replace my crappy Bose door speakers in my 09 Mazdaspeed3 GT, plus some Pioneer TS-G520s for under the front seats. Along with those, I picked up a Kicker 46HS10 Hideaway Subwoofer with a 180-watt amp built in for the trunk. It comes with "quick connect" wiring, which according to the Crutchfield rep who helped me was all I needed. I also plan to keep my stock radio as I don't need anything fancy and should do the job just fine IF I wire it the right way. From what I've heard, installing with the Bose system is different than if you had a non-GT model. This is where I need help.
I want to wire everything in correctly which I believe is through the Kicker Sub/Amp rather than the stock amp. There are some forum writeups out there for sub installs in these cars, but none so far covered a Sub with a built-in Amp, especially with the Bose system for gen 1s. If you know of writeups on this subject specifically, please send them my way.
Will I need to go through or around the stock amp? How do I install this all correctly?
Every tidbit of information/help is greatly appreciated! Thank you!
EDIT: If I'm being silly by keeping my stock H/U and would be way better off with an aftermarket one, please let me know!
