chris' speed 3
ENGINE/DRIVABILITY
Year/Make/Model: 2010 mazdaspeed 3
Mileage: 225k km, rebuilt oem spec engine has 20k
Concern: -14 LTFT at idle and around -9,-6 while driving
DTC's: p0455 (Evap gross leak)
Modifications: bone stock (for now)
ECU/Tuning Software: AP
Tuner: not tuned
Is the concern intermittent? no
Can you duplicate the concern? yes
So having issues with negative ltft, I don't know how long this has been going on as I just recently installed my accessport with a stage 0 map from cobb in preparation for some mods and a tune from justin.
I have been having a long crank issue intermittently mostly when the engine is warm since i bought the car in july 23'. Spark plugs are good and gapped at 0.026 and injectors were serviced when the engine was put in, seals were replaced with oem seals.
I'm thinking an injector is leaking as that would explain the long crank as well as the negative ltft, just don't want to spend money on seals if it could be something else like the evaporator system maybe
Tuner: not tuned
