Jwayne
Hey guys I need some help to give some context I have a 2013 tech package ms3 with a BOV, Auto tech HPFP, muffler delete and everything else is stock. I also have a Cobb accesport that I track my car with. I noticed that my ltft goes up into the negatives after I do some pulls. For example when I am cruising I am around -7.81 and when I go WOT it goes to -2.34 or -1.56 sometimes even 0, after a couple hard pulls it goes to -9.83 on idle and cruise and settles till I drive normally again and goes back to the -8 and -7 areas. I heard even at cruise -7.81 is still high should I be looking for leaks? Boost is holding stock psi 15.3, Afr Is 14.7 on idle, HPFP pressure is 430.
Thank you for any help.
