-Overspeed Built Motor(Built For 700hp)
-Grimmspeed Ebcs
-Guardian Angel
-HTP 3.5" Intake W/Recirculation Tube (Recirculation Tube Blocked)
-4" to 3.5" Coupler For Intake
-St Manifold W/PI Adapter
-1000cc Bosch Injectors
-Split Second Controller
-NGK 6510
-DM STAGE 3 Dual Occ Kit(Running Route 3)(replaced vented can with big 10an can off ebay)
-DM Pcv Vent Plate (New Version)
-Gen 2 Valve cover W/Vented oil cap
-Bosch 4 Bar Map
-Turbosmart Dual Port BBV(Full VTA)
-Autotech HPFP Internals
-Fmic (Treadstone Tr1035 Kit W/Crash Bar)
-CPE Exhaust Manifold
-Kosmic 3" DP
-Tial Mv-R 44mm Wastegate
-Kosmic Dump Tube
-PTE 5558 CEA Gen2
-Hellcat Fuel Pump
-Spin-on Oil Filter Conversion Kit
-Sandwhich Plate W/Sensor Holes
-Transfer Case Bearing Caps
-Sure Rear Diff Mounts(Both)
Rev 5 Oil Cooler Kit
-Whilteline Rear Sway Bar
-Adju. Sway Bar Linkage(Rear)
-Fuel Lab Fuel Regulator
-Custom 3" Single Exit Catback With 2 Vibrant Ultra Quiet Resonators
I'll start off by saying I did not have the Gen 2 valve cover w/vented oil cap at the start and I was only running the damond motorsports stage 3 occ kit(route 3)
Went thru break in no problem. starting tuning with freektune.
Went thru 91 Di tuning no problem.
Went thru 91 Pi no problem yet
as we went thru E33 Pi tuning when we started getting above 30 psi, the car started having issues with oil coming out vented occ,
I talked to Justin from freak he suggested replacing the vented can stating the dm occ's are too restrictive. So i grabbed one off easy that was 4 times the size and had dual 10an fittings and dual vents.
It seemed to help and we continued tuning.. as the boost and power went up the occ was filling up and spraying out every couple days. And around 36psi of boost the occ was filling every other day. I finished the tune. But never got to run the last two tunes because oil would spray out every drive with ethier one.
So i stayed on the 3rd to last Pi e33 map which cap boost around 33 to 35. I was draining the occ every 3 days or so and checking oil then as well. Drove like this for last couple months. Then I ended up in roll over accident(details of accident not important. But drivetrain was saveable)
Damage to drivetrain
-Boost tube over valve cover to fmic pinched closed
- fuel pressure regulator snapped off pi fuel rail
-pi fuel rail slightly forced down and broke housing of 2 pi injectors
After a few months I bought a new roller.
I had bought car back from insurance and by passed the pi fuel system and i was starting it every 2 weeks for a hr during these few months.
I transferred everything over replaced need parts that broke
Got the car driving on 91 pi no problem but everytime I try the pi on 91 its a no go.
I replaced the pi injectors with same brand and cc Injectors
I was still getting oil coming out the occ and I was trying to figure out what I did wrong with the build to be getting this issue Still
Then I realized I never got the Gen 2 valve cover with vented cap. So I got that put on. Now occ does not fill up often but now I'm getting oil sraying out the vented cap every drive.
So i bought the new version pcv valve plate with bigger opens had the old version before.
So I did a compression test and got this(im in colorado high Altitude so 150psi here is 180 at sea level)
Dry / wet
130. ? cylinder 1
130. 140
120. 140
105 135
(cylinder one wet test couldn't be completed battery died during testing)
So did blow by from not having gen2 valve cover kill the motor?
It has around 20k mile i believe. Just eant to be sure i figure it out and address it. Before moving forward to repair motor. All advice is greatly appreciated
I know thr rings seated properly. I had no knock issues during tuning and power felt great.
Thank you for the help fam!
-Grimmspeed Ebcs
-Guardian Angel
-NGK 6510
-Bosch 4 Bar Map
-Kosmic 3" DP
-Kosmic Dump Tube
-PTE 5558 CEA Gen2
-Hellcat Fuel Pump
Dry / wet
130. ? cylinder 1
130. 140
120. 140
105 135
