New Part! High Pressure Fuel Line
CorkSport - Derrick
Its here! The high pressure fuel line which includes alternate fuel compatibility, including beer!
Link for the fancy new part from CorkSport for your Mazdaspeed
Enjoy
-Derrick
Any plan on replacing the yellow clip and blue clip low pressure lines? Those things are notorious to messing up if the colored retaining clips get damaged, and they lines are pricey to replace for what they are. I don't know of any sources to get the replacement yellow and blue clip portions of the lines, only whole new lines themselves.
You can make your own low pressure lines with russel fittings and braided hose. I have part numbers if needed...
Hats off Corksport for staying in the game for us!
Here is a shitty picture of the feed line with -6an fittings and compression fitted ptfe braided hose
Part numbers would be appreciated. My blue connector line into my HPFP has given up on life and pops off with the ITFP pressure. And the cost of buying a whole new line is close to $100, IIRC.
I made my own low pressure side as well. Earl's AN fittings and some hose from summmit. Pretty easy
Did you put one together?
I actually have one I bought from a guy in our area who purchases used/salvaged Speeds and parts them out. When it warms up a little, I'll try throwing that on and see if I can finally get rid of the zip-ties keeping it in place/not leaking.
