The one and only solution for keeping your flywheel bolts from backing out! This is the same combo we run on all of our shop cars with upgraded clutch kits, along with many other high horsepower high revving Mazdaspeeds and Ford Ecoboosts. ARP Flywheel Bolts coupled with Nord-Lock Locking Washers will keep that flywheel secure, and help to prevent your flywheel bolts from backing out.
https://damondmotorsports.com/produ...nord-lock-washer-combo?variant=47551405424927
Nord-Lock wedge-lock washers works off of tension instead of friction unlike standard lock washers. More info in this brief video here.
We offer this kit with 2 different sized washers, to allow for fitment on various flywheels where the bolt holes may be recessed (see photos). If your flywheel does not feature recessed bolt holes, be sure to select the larger washers. If your flywheel has recessed bolt holes, you'll want to measure the diameter to confirm compatibility. Any questions on selecting the correct washer for your flywheel, please reach out to us. Verified fitment guide below.
Small Washer OD: 0.770"
Large Washer OD: 1.005"
We recommend using a high strength threadlocker & sealer on the bolt threads, and a torque value of 105-115lbs/ft.
Verified Fitment:
Mazdaspeed3 and 6:
Verified Fitment:
Mazdaspeed3 and 6:
- OEM/LUK - not compatible
- Fidanza - Small
- ACT - Large
- Clutch Masters 725 and 850 - Large
