GCPhotographers
Test update with power, signal and ground...I have positive reading from 1 through 3 but the 4th connector is negative.
I will update tomorrow evening. I am looking forward to finding the issue and resolving it. It's been too long?For better or worse at least you have a lead now
I heard the wotbox failing is common. Is that true?Annoying for sure but at least you found it!
really or messing bro?No idea
Congratulations, gotta be a relief!
What are you referring to?For the love of all that is unholy, please don't make people google codes.
A Camshaft Position Actuator Control Circuit Low Bank 1 meaning the P2088 error will be stored if the camshaft fails to adjust as per command. With the help of oil pressure, the PCM will advance or delay the timing of the camshaft, which alters when the valves open and close. Also a connect with a failed or failed oil control valve. It can also be wiring.Type out what p2088 is
