Chemmedic
I honestly don’t think it sounds like a head gasket but cylinder #3 sounds like it’s not doing so hot lol I built my motor recently and had my hpfp leak at the block. It barely still is but apparently some people say it takes a dab of BLACK rtv at the 12 o’clock and 3 o’clock positions.
It is supposed to go on the side of the gasket that goes against the block. I feel you are experiencing several things at once which makes it seem worse than it is. I would suggest looking under the car at the oil filter/oil cooler area (which is known to leak). Remove the hpfp from block and clean it up, then check the oil drain line for leaks. Also, the oil pan could have a loose bolt or two or the washer could have been left off the oil drain plug.
All things I have come to realize are minor things that I have addressed to fix my oil leak issues.
About to do this right now. Thanks for the advice on this one.
