P0139, P0172, and P0234
  • Thread starter Thread starter jsmith
  • Watchers Watchers 4
jsmith
Silver Member
Codes are:
P0139 - 02 Sensor Circuit Slow Response
P0172 - Fuel System too Rich
P0234 - Engine Overboost Condition
I am guessing its the MAF, as the STFT/LTFT readings suddenly jump to/from large and static values.
Cold start idle log is attached.
Any input, or past experiences with similar issues would be appreciated.
If you hold the throttle a bit while cranking to bypass the cold start routine, do the codes appear again?
The cold start routine is pretty neutered via the tune.
I'll give it a try, but so far the codes have reappeared across battery pull resets.
Was pretty sudden. Car drove well enough before I parked it for a month or so. Car drives well enough as long as no WOT.
No reason, just being stupid.
With the issues that you and Raider are having, I wonder if I should change mine for good measure....
