Hey Folks,
hoping one of you can help, cleaned injectors, intake valves etc. reassembled, now I'm getting p0202 Cylinder 2 Injector Circuit Malfunction
cleared code, it comes back, check electrical connection, still there. tested harness for cycl 2 its fine. really hoping I didnt pooch the injector somehow? that being said I did pinch the injector to rail o-ring massive leak and just replaced them, car did not run enough before to notice if I threw a code before shutting it off with the fuel light.
Wondering if it's worth moving injectors between cylinders at this point to see if it is in fact the injector. thoughts?
@Sho @Enki
@Sho @Enki
