TheBourgeoisie
So I have this lingering p0443 code, which seems to be a purge valve code (08 ms3). I swapped the purge valve for one I had from my old speed6 (the inline one that sits by the HPFP), cleared the code and it came back. It doesn't feel to be having any issues associated with it, doesn't seem to be affecting idle AFRs and it drives fine. I had considered replacing the line from the purge valve to the intake manifold, but I believe the line is clear because I was able to blow through it when swapping the valve. Any suggestions?
