Parts database
VTMongoose
John/MD1032
Has any consideration been given to creating a section of the forum or sticky with a database of parts?
For example, recently I needed to order an intake manifold gasket, so I had to log onto Mazdaspeed motorsports, look up the OEM part number via the diagrams, then order it. I also ordered a Beck/Arnley off Amazon which ended up being the exact same part. Ideally there would be a place where I could log this fact so that the next person who orders an intake manifold gasket knows they can just order the Beck/Arnley one off Amazon.
I'm not saying it has to be a RockAuto catalog, just some kind of table or list.
I have access to the stock parts list via mazdamotorsports. So if you ask for a part, I can look up the part number, or at least get a picture up of the parts number for it.
Yeah...did you read my post buddy? I ordered the intake manifold gasket from Mazdaspeed motorsports... lol
And that's not the point anyway.
Other place had a thread of OEM part numbers. Could start with that and expand on it.
here's a start. Yeah, create your own thread and maintain it.
mazdaspeed accessories
mazdaspeed3 coilovers - RAMS8ML10
mazdaspeed3 springs with 2 rear camber links - GRMS8ML25
mazdaspeed3 rear camber links - GRMS8ML07
mazdaspeed3 cold air intake - GRMS8ML29 - who knows if they sell this?
mazdaspeed3 cai filter - GRMS8ML10
mazdaspeed3 exhaust - GRMS8ML26
mazdaspeed6 springs - GRMS8MH14
mazdaspeed6 cold air intake - GRMS8MH32 - who knows if they sell this?
maintenance
regular filter with o rings - L321143029U
spin on conversion - L31114311 and gasket - LF0114342
spin on filter - LF0514302A
drain plug washer - 995641400 - this normally comes with the filter
filter wrench - AKS75140
spark plugs - 000018L3Y3
drive belt - L3K915909A9U
radiator thermostat - L33615170
ignition coil - L3G218100A9U
Lighting
OEM HID ballast/control module for 3, CX7, CX9 - D530510H3
exterior
front bumper mustache - BA6R50B31A - to remove the holes left from your front plate bracket
undertray aka lower shield - BP4K56111L
undertray fasteners/clip-nuts (sides, need 4) - BAY6-56-496 or BR5S-56-496
undertray fasteners/clip-nuts (front, need 3) - FB01-50-133C
undertray bolts (7 total) - 90720-0620 (old) or 90720-0616 (new, shorter bolt)
skid plate, radiator support, the piece that is on the bottom in the front of the vehicle - BP4K56112
mazdaspeed3 wheels - 9965097080
mazdaspeed6 wheels - 9965117080
forged mazdaspeed wheels - BLMS8MZ01
center caps - G22C37190A
interior
coin holder - G22C55225
shift knob - GP9A46030B
under the hood
cylinder block - L3K910300H
valve cover - L3M610210A
mazdaspeed3 battery box tray - B37F56040D
mazdaspeed3 battery box and ecu cover - L33X18593B
mazdsapeed3 battery box front panel - L33X18591A
tmic cover - L3K9207B0F
oem egr tube - L3K920310A
oem egr valve - L3K920300
maf - L3K913215
map - L3K918211A
pcv - L3K913890
primary o2 - L33X188G1C
secondary o2 - L34B18861A
boost solenoid - L3K918741
ambient temp sensor - G51861764
knock sensor - L80718921
crankshaft position sensor - L3K918221A
mazdaspeed oil cap - BLMS8ML02
oem fuel pump - L3K91335ZC
oem boost tube from turbo to intercooler - L33L13760B
mazdaspeed3 (fits 2007 ms6) oem boost tube from intercooler to throttle body - L33X13770A
mazdaspeed3 oem cold pipe - L33X13241A
2006 mazdaspeed6 oem cold pipe - L3K913241B
2007 mazdaspeed6 oem cold pipe - L3K913241A
turbo oil drain/return line - L33E14290
gasket for top - L3K914293
gasket for bottom - L3K914264
bolts for previous two items - 9XF002127L
tensioner pulley - LF1715980E
OEM cam follower or "collar" - L3K9-12-615
brakes
mazdaspeed3 caliper bracket bolt - 9YA02A225
mazdaspeed3 front brake pads - B3YF3323Z
mazdaspeed3 front rotor - B37F3325XA
mazdaspeed3 rear brake pads - C2Y32648ZA
mazdaspeed3 rear rotor - C25Y26251B
mazdaspeed6 front brake pads - GPYA3323ZG
mazdaspeed6 front rotor - G31Y3325XA
mazdaspeed6 rear brake pads - GPYB2648Z and apparently you need this as well - GPYB2649Z
mazdaspeed6 rear rotor - G31Y26251
suspension
mazdaspeed3 front sway bar - B37F34151
mazdaspeed3 front end links - B37F34170A
nuts for front end links - 999401001
mazdaspeed3 rear sway bar - B37F28151
mazdaspeed3 rear end links - B37F28170A
nuts for rear end links - 9YB101005
gaskets
head gasket - L3K910271C
turbo to manifold - L3K913710
turbo manifold to head - L3K913460
downpipe to turbo - L3F213490
intake manifold gasket to head - L3K913111
throttle body gasket - L3K913655
donut gasket - L3A140581
bpv to cold pipe oring diamond shaped "gasket" - L3K920255
fasteners
turbo and manifold studs - L33E13146A
nuts for studs - JE1040355
miscellaneous
Maybe it's been done, but I am willing to put together parts database for people to access. I specialize in enterprise web applications and database development. This seems like it would be fairly simple to get going. But it would be only worth the effort if there was enough interest in it.
I'm interested and i think it would be a great resource for mso.
tapatalk, it sucks
I'm sold...and will contribue as I can. About to undergo a build and will need to replace a bunch of stock stuff
