Phate@2GFab
Grass-Roots Vendor
So we bought this house in 2018, and it had a 30x36 detached garage. It was just bare studs and rafters, with about 3 light bulbs. This post will get you up to speed with everything done up to winter 2024, then the rest of the thread will be about the projects I have going now.
We insulated it and finished it out with drywall a year or so after buying. I put a small landing in the attic for a little bit of extra storage. It had a 30A sub panel, so I wired in a bunch of 120V outlets, and a couple 240V outlets.
Apply some paint:
That brings us up to ~2023, where I added a 80k BTU hanging propane heater. I have 3 100lb propane tanks behind the garage for this, because our gas meter is on the other side of the property, and I didn't want to tear up our deck and trench 200' to get gas to the garage. We also built some shelves, which are under (ish) the heater.
Equipment wise, I've been running a Monarch 10EE lathe and Bridgeport knee mill. I love the Monarch, it's all original from 1940 with the Sundstrand drive. It's worn, but it still cuts well within the tolerance I need for parts. The Bridgeport is pretty clapped out, but I got it for a steal. I'll be replacing it in the near future.
To handle the 3 phase power the lathe needs (the bridgeport was converted to a single phase 230V motor), I installed a small rotary phase converter. It's a 10hp phase converter (AD-10 from American Rotary), which can start and run the 5hp motor in the lathe (they're sized at 2x motor rating to handle start current.
I also have a small bandsaw and 29gallon air compressor from Harbor Freight, a 20 ton press, and a PrimeWeld TIG welder that all get used a great deal.
So that brings us up to the current state of affairs. I'm planning on bigger things (more on that later), and that requires more of pretty much everything.
Apply some paint:
- Electrical - My 30A panel isn't going to cut it.
- 200A dedicated service for the garage
- New phase converter and 3 phase breaker panel
- Air - My current 29 gallon air compressor isn't going to keep up
- I need a dedicated drop for the new machine, and want to pipe in a few extra drops and reel just to make life a bit easier
- Dry air is a must!
- New compressor with more capacity and more flow. I want to set this behind the garage on a pad to cut down on noise.
- Concrete - 4" isn't going to cut it
![20241115_125227[1].jpg 20241115_125227[1].jpg](https://www.mazdaspeeds.org/data/attachments/30/30246-2af824f27e1ac7d570df172853823456.jpg?hash=Kvgk8n4ax9)
