Monkeywrench
Silver Member
2008 Mazdaspeed 3, 165k-ish, currently all stock suspension.
Will be installing less than a year old suspension from my first Speed 3 that I returned to stock proir to selling, but want to change out all the suspension bushings as a "preventative upgrade/all done in one shabang/one after that fact alignment" effort.
I'd be happy enough with factory rubber, but don't want to mess with, or chance aftermarket rubber replacements, or even look at OEM costs.
So poly it is.
Parts going on.
Bilstein B8
H&R Sport springs
Godspeed rear camber arms
front strut camber plates. Forget brand. From Poland. They did what I wanted, allowing to adjust camber to around 1 degree for tire wear.
So for a bushing kit, just looking for stock replacement, not any additional enhancement with specially designed bushings for altering caster/or camber (Superpro). Stock-ish ride (lower durometer) bushings would be ideal.
Super pro though generally well regarded to my undertsanding, is a bit pricy at $699 for the full kit.
PSB full kit (only offered with wrong option for sway bar bushings, no biggy as I have those replacements already) far less at $175.40
psbushings.com
Neither actually list the durameter, which i know would really only come into play for apple to apple comparision if the two production thicknesses/masses were the same between the two venders anyway.
PSB states "the highest grade of polyurethane and the durometer of the bushing is designed to fit the application", which would make me believe maybe a softer bushing/closer to stock ride versus more performance based pitch of Superpro.
Anyone have expeirience with either, or any other I may not have considered offering a full kit?
Anyone have expeirience with both?
Any other input, advise or thoughts I may not be considering?
So poly it is.
Parts going on.
Bilstein B8
H&R Sport springs
22 x Mazda 3 (04-09) Complete Front & Rear Bushings - Polyurethane Suspension Bushings
Notify Us The ID of Front & Rear Sway Bar During Checkout.
psbushings.com
