Indeed. Hopefully enough moons will have passed soonWe said we were having a problem getting a manufacturer which doesn't suck many moons ago.
-Derrick
-Derrick
Well stock injectors are ~1700cc, so the two best options would be 2210cc (+30% for full corn boys looking for 400 whp) and 2550cc (+50% for the bigger big turbo guys looking for some low/no mix 500 whp). Anything higher is probably safe to relegate to dedicated aux fuel.
Let's say 1800 PSI for the sake of argument; flow won't improve much at 2k PSI anyways.What pressure are those numbers measured at? We are going for large end of the scale to give a broad range of use.
Getting an AEM dryflow filter will reduce a LOT of intake noise.Assuming they are quieter. Or just design a quieting system onto the current offering. I want big flow but I personally don't want all the air rushing, whistling and whining noises.
Heh. A dryflow came with the Freek 3.5" that I have on the car right now (it's the same as the no-straightener HTP 3.5). LOTS of intake noise; it's obvious when the turbo's spinning. I just don't know if the whistle at WOT is a boost leak or the turbo. LOL.Getting an AEM dryflow filter will reduce a LOT of intake noise.
I'd like to see some accurate testing done, and solutions found, for reducing underhood temps.Post your product ideas on what you guys think that CorkSport should make next!
I had the whistle until I got the BNR on. Whistle gone. This led me to strongly believe the whistle was a leak. It's a very characteristic sound too...Heh. A dryflow came with the Freek 3.5" that I have on the car right now (it's the same as the no-straightener HTP 3.5). LOTS of intake noise; it's obvious when the turbo's spinning. I just don't know if the whistle at WOT is a boost leak or the turbo. LOL.
I am, however, going to switch to the JBR silicone that I also have, and we'll see how that sounds. It also has a dryflow, of course. I came from stock, and I guess I have no idea what a "normal" sound is for an aftermarket intake of either type or if it's going to be higher on the HTP with its integrated MAF than on JBR/CS with coupler'd MAF.
I have a 3" CS SRI and didn't notice any whooshing noise until I added a ETS TMIC. Not sure why it made a difference, but it sounds like a wind tunnel under the hood now.Heh. A dryflow came with the Freek 3.5" that I have on the car right now (it's the same as the no-straightener HTP 3.5). LOTS of intake noise; it's obvious when the turbo's spinning. I just don't know if the whistle at WOT is a boost leak or the turbo. LOL.
Not a whoosh, but a whistle. I'm not sure about your noise either. The whistle is very distinct...I have a 3" CS SRI and didn't notice any whooshing noise until I added a ETS TMIC. Not sure why it made a difference, but it sounds like a wind tunnel under the hood now.
i would like to see this aswellA front Pu bumper that looks awesome
Could we get a nice aluminum radiator shroud to cover the open gap like the genpus but could there also be a version for those who want to stay tmic which would either A) allow stock plastic air deflectors or B) have aluminum deflectors molded into the shroud as a sold piece??
Just curious: does the way that's designed/installed help with the notorious Genpu bumper sag? Seems like if it were designed with that in mind, it could be a very good solution.
