What route would you run for safest and best flow?Shouldn't have a problem running it, so long as you have a PCV plan mapped up. You would need a check valve or factory PCV valve somewhere since this plate eliminates it at the factory location.
If you have any insecurities about it, there are plenty of vendors that make them with other configurations (Full Race, Damond, Perm, and others).
So you have two catch cans correct? Sealed or vta?Well... the way I have mine set up now...
PCV plate (with straight hose barb)...>
Catch can...>
90* hose elbow/OEM PCV valve...>
Check valve right at Manifold.
The check valve locks boost out of the crank case, and the OEM valve keeps excessive vacuum from being pulled through the check valve by the manifold. Catch can never get's boost exposure.
