RaiderFab now offering Quik-Latch Hood Pin Kits!
  • Watchers Watchers 1
Raider
Administraider
Administrator
RaiderFab is a proud distributor for Quik-Latch, the original American made latches NHRA Certified and proven to stand up to the elements!
Designed with the import performance market in mind, the QL-38 series hood pin kits deliver the same push button function that you've come to expect from Quik-Latch Products while retaining serious holding ability that is required of hood pins. The reduced Physical presence of the 38 series hood pin kits ensures a clean and unassuming look that will blend in with your overall build.
You've spent thousands upgrading your car's mechanicals, electrical, body and paint. Why install a hood pin made of substandard materials that could rust after just a few years? Go with Quik-Latch hood pins and make the finishing touch to your project car representative of the pride you have in your ride!
Our first offering is the most requested. The locking QL-38 in black! Also available in machined and polished by special order.
Specs:
Materials: 6061 T6 Aluminum / 303 Stainless Steel
Holding Force: 500lbs per latch
Weight: 4.7 ounces
Height: 1.50 inch (38 mm)
Height Below Mounting Flange: 1.375 inch (35 mm)
OD of the latch mounting flange: 1.75 inch (44.5mm)
Thread size of latch body: 1 1/8 x 24 UNEF
Hole size required to mount latch: 1.25 inch (32mm)
Pin dimensions: 3/8" ball with 3/8 x 24 thread
Retaining Ring: 1.50 inch (38mm) OD x .25 inch (6.4) thickness
Minimum distance from top of mounting surface to mounting point: 1.125 inch (28.50 mm)
Maximum distance from top of mounting surface to mounting point: 3.50 inch (88 mm)
Maximum mounting angle: 18 degrees
Distance needed to engage pin into latch: .687 inch (17.5mm)
https://raiderfab.myshopify.com/products/ql-38-series-lockable-hood-pin-kits
