I am not sure I can really call this a "build" as much as I would call it a diary.
Current configuration:
2009 GT. Here's my introduction thread:
https://mazdaspeeds.org/index.php?threads/hello-mazdaspeed-bretheren.10652/
I also have most of my parts listed in my signature. My wife actually bought me this car, new in 2009 as a celebration of us fighting through marriage problems and succeeding. I will never sell this car!!
Problem Statement:
Went on a road trip with my 16yo son and this happened:
https://mazdaspeeds.org/index.php?threads/did-my-turbo-just-puke.10653/#post-80315
So I asked a bunch of questions here:
https://mazdaspeeds.org/index.php?threads/should-i-replace-or-rebuild-my-turbo.10674/#post-80165
and here:
https://mazdaspeeds.org/index.php?threads/how-do-i-pick-a-tuner.10724/#post-80311
Then ordered a BNR S3 and it's related goodies.
Cleaned my valves; they were not as bad as they have been. Here's when I started.
I use gasoline to soak the gook. Usually, I just drop about 1/8-1/4 cup of gas down there, let it sit for about 10 mins, scrape around with a long pick I have, let it soak another 10 mins, then pull the gas out with a paper towel.
Then I take the old walnut shells to the valves trick. I tried using a vacuum the first time I cleaned my valves and found it does not prevent as much of the mess as it should and I felt like it slowed the walnut shells making them less effective at removing the goop. So now I just make a tent and tape off the area like a dentist and blast away. It cleans the valves super efficiently and I use hardly any shells. Cleanup is not so bad because they all land on the sheets or the floor at my feet.
Of course, I made sure I wouldn't catch the 'Rona while blasting because I had on my N95 mask.
Cleaned everything up but didn't really put anything back together while I wait on my Turbo and it's pals. Notice my car is still filthy from the road trip where my turbo died. Poor dude!
This bracket has been broken on my engine for a long time. Probably at least 8 years. There is a dude in LA that parts MS3's out and he says he has one. I could weld the stocker back together but my welding skills are almost as good as my modeling skills (NOT good). Do these break a lot? It's the bracket on the HPFP that holds alot of the engine harness and vacuum lines. The turbo inlet also hangs on it.
I also mangled the heat shield/blanket thing that hangs on the firewall when I was pulling my Turd-bo out. This was before I wrestled it out. It's much worse now. I will order a new one.
All my parts are spread out in the garage. Looking forward to the new ones getting here (hopefully) later this week.
I just sent $$$$$ To Freektune today. Tomorrow I have to order some little odds and ends (gaskets, etc.) in prep for my new S3. I also plan to clean out my intake manifold and EGR valve while I wait. I am pretty tapped out financially at this point. I need a CC but don't have the cash. When I reinstall my intake I am going to run a line from the PCV to the driver side frame horn, then back to the intake. That way when I do have some cash (hopefully the end of the summer), I can just order a CC, cut that line at the frame horn, and install it without having to mess with the PCV system.
Any advice? I am more of an AMC/Jeep guy so even though I have had this car for close to 12 years, I consider my self an MS3 NEWB. I know my stock TMIC and Downpipe are going to choke my S3 but I am OK with that for now. I will watch Craigslist/FB Marketplace to see if I can find used ones later and get them installed when I can.
Problem Statement:
and here:
