Seal Greenie Member Jan 23, 2025 #1 I got the Damond motor mount set and I wanted to know if I only need to use jack stands on the front end of the car to elevate it enough to get under to access the RMM, or if I needed to get the whole car elevated on stands to access it.
Easter Bunny Professional Engineer Motorhead Jan 23, 2025 #2 Depends on what size pants you wear. Front should be enough. Put the jack under the motor before disconnecting the existing mount to make it easier to line up the new one
