Justgregkas
Hey guys so here’s the deal, something’s going on with the speed, but I’m not sure what it is. I’m getting an intermittent vacuum leak, that causes a lean status. While driving, there’s no issues. It only occurs are idle or when stopped.
I will add that when the AC compressor turns on, it also happens, but it also occurs with the AC off.
So, let’s here’s some ideas of what could be causing this problem; happens at idle and sitting still.
1. Purge valve - replaced
2. Pressure relief valve on fuel rail?
3. PCV is new as of October 2023
4. All my vacuum lines (silicone hoses, most if not all are direct and have no breaks or joints to mitigate leaks) are running through my JMF manifold; PCV valve to OCC, then to intake, BOV, purge valve, brake booster, MAP.
I will post some logs shortly with a capture of what’s happening.
Thank y’all for the help, happy holidays
