Finch204
My car is idling roughly, usually when I'm on a stoplight. This only happens when the engine is already warmed up. Doesn't seem to happen during cold starts or when the engine is below 180F coolant temp. Check engine light is not on and there are no trouble codes. My car battery was fully charged last month.
Looking at the Accessport when this happens:
Does anyone have an idea of what's wrong here? Do I need a new alternator? Do I need to clean my intake valves? Bad oxygen sensors? (I still have the oem downpipe)
- I see my AFRs go a little lean. It will spike up to like 15.23 or 15.34 or 15.45 then drop back down to the 14s.
- At times before the AFRs spike up, the LTFT will go up then back down to its normal idle value.
- The battery voltage at times also drops down to like 13.4-13.6 when this happens. Yesterday it dropped all the way down to 13.0.
- While all that is happening, the car is vibrating more than usual. It is not the same as when the AC compressor kicks on. It is a noticeable vibration or like I said, rough idle.
