Hey
I'm in the process of upgrading my methanol injection setup by using a new controller requiring a rpm feedback.
I searched and found a Mazda technical bulletin for remote starter connection with a white wire out of the ecu harness made exactly for that...http://am.mazdaserviceinfo.com/libr.../en_us/pdf/Remote_Start_Addendum_(Mazda3).pdf
I checked it with a meter and see an average voltage and frequency fluctuation corresponding to rpm so i was confident it would work....tried it, worked for a short time and after few rev, engine fall on 3cyl and ending up burning cyl #1 coil and blow ignition 20a fuse...youpi!
After replacing everything, i checked that white wire is directly the firs wire of the #1 coil. I will have to double check with a scope the exact signal and why it wasn't compatible.
So is any of you used to connect a rpm feedback to a device ? If so please let me know which signal you have used...
My last call is to add an extra crank sensor and keep it completly separated but i expect some of you already figured this out and i'm looking for advide.
