Shadowplane676
Thanks StreetSpeed6, but currently the stock BPV I have appears to test out fine. I will let you know if it comes up as a possible issue after reassembly.
So despite not believing the turbo was knackered, I sent it off to a local turbo rebuild shop for analysis. Got the call yesterday from the shop and the tech informed me that the turbo was in need of a rebuild. He found metal pieces in both the journal bearing and the thrust plate feed area. Add in the fact the oil feed gallery was plugged, it would explain why the turbo wouldn't spin up fast enough to provide more than 4psi of boost. He did confirm that all the rest of the turbo, including the wastegate checked out fine.
At this point, it was decision time. Do I go with a rebuild, an OEM replacement or a CST 4? In the end, given my vehicle situation, it made the most sense to have my current turbo rebuilt. For a reasonable price, my stock K04 will be getting overhauled along with a new CHRA, turbine and compressor wheels. While a CST4 would be nice, the cost plus time/effort/risk of daily driving a vehicle in the process of tuning outweighed the install and drive aspect of a stock turbo. Also given that the general goal for this speed is stock-ish, constrained by being reliable on major stock components, a CST4 may be in the cards down the road. Going with the K04 will also allow me to get up to speed with Mazdaedit and get some extra power out of the K04 before taking on the CST4.
I will however, be adding a catless downpipe, HPFP internals and Corksport injector seals while I am in the car for reliability and longevity reasons. Not too far in the future will also be a FMIC setup.
