need4swede
THE CAR
Color: Silver
Mileage: 298,xxx
Year: 2007 (Gen 1)
CURRENT BUILD
Chassis & Suspension: 100% OEM (Yes, even the RMM!)
Brakes: 100% OEM
Body & Lights: 100% OEM
Engine & Cooling: 100% OEM (with 01-002/11 Service)
Drivetrain: 100% OEM (currently on my second clutch)
Wheels: Mazdaspeed 6 OEM Wheels
THE REVIVAL
Links navigate to where I actually bought the part from.
Vendors were chosen based on availability and cost. Your mileage may vary.
+Bilstein B8's (FL: 35110767 / FR: 35110774 / Rear: 24-215237)
+Bilstein Shock Boots - Blue (E4-B30-650N1)
+Damon Motorsports Mounts (3 Piece Kit)
+MOOG Front-Left Lower Control Arm (RK620041)
+MOOG Front-Right Lower Control Arm (RK620040)
+SPC Adjustable Rear Camber Arms (SPC 67420)
+Strut Mounts and Bearings (Front: 924419 / Rear: MP906981)
+Swift Pro R Springs (4Z906R)
+URO Parts Rear Bump Stops (1J0512131B)
+Whiteline Anti-Lift Kit (KCA428)
+Whiteline Front End Links (KLC151)
+Whiteline Front Sway Bar, 27mm (BMF57Z)
+Whiteline Rear End Links (KLC185)
+Whiteline Rear Sway Bar, 27mm (BMR88Z)
+Whiteline Full Swaybar Kit (BMK001)
+2.3L Longblock from Mazda (curtesy of Overspeed)
+AutoTech HPFP (10-127-100K)
+BNR S3 V3 (BNR-MZ3)
+Bosch 3 BAR MAP Sensor (281006077 / Adapter: RPM-MAPPNP)
+Cobb Accessport v3 (AP3-MAZ-002)
+CP-E TMIC (MZCK00004T)
+Damond Motorsports Oil Catch Can - Stage 1 w/ VTA (DM3OCC1BKVTA)
+Damond Motorsports PCV Plate Kit (DMPCVG)
+GFB Blow-Off Valve (T9002)
+GFB BOV Trumpet (GFB 5702)
+GrimmSpeed EBCS (57028)
+JBR 3.5" Wide Path Full Aluminum Intake (MS3/6-WP-35-AL-BLK)
+Mazda OEM Ignition Coils (L3G2-18-100B-9U)
+Mazda OEM Serpentine Belt (L3K9-15-9099U)
+Mazda OEM Thermostat (L336-15-170)
+NGK Iridium LTR7IX-11 (6510)
+Overspeed Injector Seals w/ cleaning (curtesy of Overspeed)
+CorkSport Hanger Bushings (Axe-6-087-10)
+CP-E Long Catted Downpipe (MZDP00002T)
+Ultimate Racing 3" Catback [Resonated, No Cat/Muffler, Titanium Tip] (80014)
+Damond Motorsports Short Shift Plate (DMMSSPG)
+DTA CV Axles (MZ23132302)
+Luk Clutch (10066)
+Luk DM Flywheel (DMF118)
+Luk Master (LMC467)
+Luk Slave (LSC572)
+Mazda OEM Flywheel Bolts (L304-16-311)
+Mazda OEM Fork (L305-16-520)
+Luk Clutch (10066)
+Luk Slave (LSC572)
