Starting speed 6 with no key?
lasangelos
Now the car is totaled
I have the fob, but couldn’t get it to work even glued it back together & changed batteries, but it was torn apart when I found it in the middle console.
I just want the ignition to come on so I can uninstall the accessport & potentially reset the ecu to factory data ...
If I do the ol “hammer ina flat head” could I make it happen?
Any help is appreciated
Remove the ignition switch from the column and manually turn it to the on position. You only need the key to start the vehicle.
Steering wheel is locked, can’t seem to get the ignition to turn, but it’s definitely got power.
Any help?
I completely remove the ignition from the column?
Alright so I made it this far
No key still
Still can’t get the switch to turn at all to get the accessories on
Any help?
Drill out the pins or what?
I thought maybe I’d need to press the brake or the clutch to turn it...
But not for acc right ?
Try just jumping the wires for the ignition switch with a jumper wire. I just suggested removing the switch cause I thought it was bolted in not riveted to the lock cylinder.
