Nitr0EngiE
So I notice when I fill my tank up in which it does not sit level and there are bumps and such while driving I think a bit of meth gets splashed up through the vent and I normally like the smell of meth, but when you get in your car to goto work it is overwhelming and I don't even want to breathe.
I can't block the vent or it will cause a vacuum in the tank and cause feeding issues, so I just copped a check valve. I went with a large 3/8 valve because the larger the diaphragm the easier it will open as the surface area is larger to vacuum on and is rated to open at 2 hg of vacuum which is nothing.
The seals are made of Viton which is really methanol compatible, and the body is made of Kyron which is polyvinylidene fluoride and is also methanol safe.
So obviously you know what is next, I am going to put this on my meth tank lid and not have to worry about fumes anymore.
https://premiumaquatics.com/products/38-kynar-standard-check-valves.html
