Is not he tune because I switched(3) maps same outcome, and I run that map that you see the log a spring pressure no spike 12.5 psi so is not the map.I aleady change al my EBC lines, switched map to a map that was spot on 3 weeks ago, check waste gate flapper (tested with air compressor) double check EBC lines connection on tri port .Last thing to do is swap EBC (ordered should arrive this week) to see because I have covered all the bases I think!!
