ShatteredPixelz
Upload the data files please
1. Don't sweat the boost difference on the stage tune; it's likely not much different (power wise) from stage 0 tune.
2. Get an upgraded HPFP when you can. Until then, don't run a stage tune that calls for HPFP if you don't have it.
3. Get a protune or learn to self tune.
4. Change your oil to a known good oil.
5. Get better gas.
I had to fix some shit in the logs (you need to log Accel Pedal Position) but honestly both tunes are full of knock and look bad.
I have no idea why cobb would release a "stage 1" map that was running lower boost and timing other than to reduce the knock you're getting (which it does), but either way, get a protune.
Seriously.
Also:
I'm currently using the best gas in the area which I guess is still shit because of california. I'll be getting a tune in 3 months when I have a job again after I finish my first year of college. Usually, in Sacramento the car doesn't knock at all. But in Santa Clara, where I am right now, the car is more knock happy. I'll be getting the HPFP in the spring when I do the VVT so yea. Thanks all for your help!I had to fix some shit in the logs (you need to log Accel Pedal Position) but honestly both tunes are full of knock and look bad.
Seriously.
Also:
