Hey everyone. Recently, I went through my entire Mazdaspeed6 and did a ton of maintenance (walnut blasting, injectors/seals, new gapped plugs, etc.), as well as some power upgrades. While the car had a TurboSmart BPV, CS TMIC, test pipe and catback before, I went ahead and installed HPFP internals, a 3-port EBCS in interrupt setup, and the Tru-3.5 aluminum intake from JBR. To begin tuning, I loaded the Base 93oct High Load map with Interrupt plumbing from the guys at VersaTune. I also borrowed the MAFCal from here. I was able to drive almost 75 miles without issues, and then I decided to dial in my MAFCal.
After making a few revisions, I was a little miffed: parts of the table from the forums were originally off by over 20% at idle, which seemed like far more than the variance you'd expect between different MAFs. Last night, the car developed a nasty stumble and stutters during moderate acceleration (I can consistently produce it with anything over 33% throttle in 3rd at 3000rpm, and it comes and goes throughout the midrange in 1st-3rd. Luckily, there's no knock). I suspected that the sensor was bad, and I changed it out for another MAF that I borrowed from a friend. I also tried loading the MAFCal that "worked" for almost 100 miles. While LTFTs were much better, the stumble persisted. The fact that the hesitation is a new phenomenon leads me to believe a sensor is failing, or there is a new mechanical issue.
I've attached a log with as many relevant parameters as I can think of. While I know that the poll rate isn't the highest on this one, I have many other logs with fewer parameters. If anyone can point me in the right direction and/or has suggestions as to what I should log, I would be very grateful.
Edit: Failing throttle body. Thanks to everyone for the help, and hopefully this post can be useful to others in the future.
