Jimmie, this is from my Speed6.  I couldnt see the crack when it was installed in the car.  It was as if the slave wouldnt push far enough to fully disengage the clutch.
Thanks. I’ll have to check it further. So what’s the fix? Weld it and then weld in some support or does someone make a heavier replacement?
			Also. Have you replace the oem rubber clutch line yet with the technafit SS line yet?
The OE line is prone to swelling and causing goofy pedal feel.
Edge auto sport carries the technafit SS replacement for the ms6
I’m still using the stock line I’ll check that out and order it today. Thanks
