It`s happened to many of us; something breaks or comes loose on a drive that forces us to pull over and inspect, often leading to a tow truck call when a simple tool from the house or makeshift solution would have had us back on the road. Introducing the "save your ass bag".
The save your ass bag is not big or bulky, not a full tool kit. It`s the essentials that will get you out of a jam that can fit nicely into the jack compartment or the spare tire well. Mine will not be the be all, end all list, so please feel free to add to it and I can update as solid replies come along.
The SYAB for my Speed 3 consists of:
1/4" and 3/8" ratchets
short extensions for each
14mm, 11mm (deep), 10mm sockets for each.
medium channel lock pliers
med flat and phillips screwdrivers
Spare t-bolt clamps for silicon couplers.
a few small worm gear clamps
an LED work light
assortment of zip ties
small side cutters
tire plug kit
and assortment of nuts and bolts. You never know when they`ll come in handy.
an empty, cleaned out soda can (can do emergency fixes on nearly any hose with this, high pressure or not. I`ve had this hold a power steering hose leak and radiator hose leaks)
phone charging cable
WORK GLOVES (if you`re on the side of the road, the car is going to be HOT)
That all fits into a small bag, and is generally enough to at the very least get you to a safer place/auto parts store. You don`t have to spend a fortune on tools for the SYAB since the real purpose is to simply get you back to your good tools. It`s meant to (as it`s name implies) save your ass when all you needed was something small or otherwise considered an afterthought.
an LED work light
small side cutters
tire plug kit
