Mazdasloww3
Saw a comment the other day from someone who claimed they knew a Ford powertrain engineer, and claimed they said that Ford didn't use the DISI (yes the Ecoboost is based on it, but not the same) because it was essentially a parts bin engine thrown together because Mazda really wanted to use direct injection. Mazda pretty much just threw a hole for the injector in the existing MZR head, which has more of a swirl flow and didn't have the proper tumble flow needed for DI to have good air/fuel mix in the combustion chamber. Anyone heard of this?
Looking into it, it makes a lot of sense. Compare the DISI head to the Ecoboost and other DI heads like even the Skyactiv, and a key feature you notice is the narrower valve angle - a big part of generating more of a tumble flow. Also notice smaller valves, which also increases tumble flow, as well as a seemingly steeper included angle of the injector with more of a guide machined into the cylinder head for the injector. It would also go to explain why the pistons in the DISI have an uncharacteristically wide and indirect fuel bowl compared to the much more targeted fuel bowls seen in most other DI pistons with an offset injector.
The reply mentioned the improper flow causing fuel washing down the cylinder walls, stripping lubrication, and causing fuel dilution. This is a known issue with the DISI, and in addition, wall-wetting causes carbon to build up on hot spots, such as the rings. However, I believe that clearly the biggest issue in all of this, is the inconsistent and incomplete combustion from the poor air fuel mixture, leading to this engine's seemingly high tendency, relatively speaking, to lean out and torch pistons, and being more prone detonation and hotspots.
Throw in the poor flowing intake manifold (ford changed the manifold for a reason), normal DI issues, especially when you throw a turbo on top, along with this platform's other quirks, and it all adds up. Although makes sense for an innovative engine like this. The DISI had to walk so the Ecoboost and Skyactiv could run.
Unfortunately, I'm not too sure what can be done with this information at this point in the speed's life cycle. A custom head especially with R&D required seems out of the question. The Ecoboost head has that integrated exhaust manifold, and a different HPFP design, but the water jacket passages do look similar at the least, so who knows. Curious to hear what y'all think of this or if this has been looked into before.
