dinodinojungle
Alright, this is a long story so bear with me.
I put Koni FSDs on my car in April or so and things have been weird ever since. I have a strange popping when I go down the road, and it doesn't seem dependent on speed. I've done not only struts, but new top mounts, bump stops, control arms, and endlinks, but to no avail. I'm fairly sure the top nut on the struts is tightened all the way, but I can't get a torque wrench on it because the strut has a hex that needs to be held or the inside free spins. I could take an impact to it, but I've read that that can do damage to the shock. I'm a bit worried that my issue is somehow related to the FSDs being longer than the OEM struts -- they're maybe 2 or 3 inches longer and required removing the entire knuckle to install.
I'm pretty sure everything is torqued properly since this is now my third or fourth time getting in to the suspension, but I'm at a loss now.
Is it acceptable practice to load the suspension with a jack in order to torque? I don't really have ramps near me.
Apologies for the ramble. Any advice is appreciated.
