The wife’s MS6 has arrived.
On that ground you mentioned where all the ground wires plug in. Wire was still in the plastic connector but was broken off from the terminal
Well most of the bugs are worked out. Still can’t get the driver side low beam to work. Bought a new bulb but haven’t put it in yet. Now just putting miles on and working on the tune. Still working on the paint but got the wheels put on today.
Haven’t updated in a while. Got everything done and engine broke in. Finished the tune and set up a dyno appointment. Goal was 600 awhp. Ended up at 636hp 502tq. Pretty happy with that since the car is still stock cams and stock flange turbo. Next goal is 800
Only 636 pssh, slow. dyno sheet or it didn't happen :p
What's the plans to get to 800
speed performance cams, +1mm ex valves and pte6466. 3.5” exhaust if CS really does end up making it. Picked up a gen 2 so I think I’m going to throw the cst6 on it and see what happens. Might also use one of my CS exhaust manifolds on the gen 2 and put a top mount on the 6.
