chrisgrissle
Just got done redoing the timing chain, got everything back together made sure the passenger ground and coil pack ground is secure.
Primed the HPFP cranked lots of times with no turnover. Car cranks just fine just won't fire.
I had tried to let it go a little longer then I should and got a p0091. I checked the fuel lines going to the HPFP to see if fuel was making it to the pump and surely there was fuel in the lines.
I'm kinda lost at this point as I decided to do the VVT to save money. Double checked everything to make sure timing was correct etc. Just looking to see what I need to do next.
Possibly replace or redo the HPFP? I'm getting no other codes besides the P0091. On the Accessport I get around 65ish pressure on HPFP that does not change when trying to start. Not sure if it's suppose to show HPFP Voltage. But I'm getting 0.0 from the Accessport.
