Torque pro pids
Dr Tal
Does anyone have the pids for our car to read bat,kr, actual afr, etc. I'm trying to just add them as custom pids for torque pro app. I have the Mazdaspeed plugin for it but the app or plugin keeps glitching and deleting the pids from the list and it's not showing up in the predefined pids list. I've tried just about everything, even restoring from a torque app backup only temporarily solves the issue.
The torque pro forum seems dead and there's barely any response from the devs.
If I knew the pod information I could just plugin the data as a custom one and call it a day. It get real annoying when I'm logging data and it deletes the pids halfway through a drive cycle and i don't get anymore data any where.
Images for the pids I need and what it does even after restoring a backup.
Screenshot_20230814-033330.png Screenshot_20230814-015454.png Screenshot_20230814-012802.png
The reason you are most likely running into issues is because I would bet that you're trying to use a device that isn't always connected to internet. Unfortunately, the add-on PIDs have active authentication and it's happening every time the device wakes, so if you don't have an active internet connection when you are opening the app/ waking the device, the PID gets disabled and even vanishes from the list till it authenticates again. This issue disappears for me when I use my actual phone for Torque instead of the old tablet I tried to use originally.
I'm no longer using torque since upgrading to an accessport v3 as it can display BATs and KR, which were the main draws of that plugin, as well as 4 other parameters you can set which seems to be enough for my needs for now.
