Totally a real build thread
jsmith
Silver Member
Forum Mods: Let me know if you all hate this method, and/or how to make it kosher.
Issues:
CEL
Airbag light on.
A/C inop. Was working when parked like 6 months ago.
Mods are as follows:
HTP 3.5 w/ modded Cobb airbox
HTP under route (mod'd to fit the heat exchanger)
HTP meth tank w/ modified fill port (not hooked up)
Alky meth controller (not hooked up)
Cobb intercooler (w/ airflow blocks c/t bumper etc) and cold pipe
Ported stock IM (its purple, but was basically free)
Gtx2867. Stock flange with hot side blanket. Swapped in at 75k miles.
Boost dial for control and tune by Stratified
Cobb AP V2 <- includes an older version of AP tuner software.
Guardian angel v2 for over pressure protection
CPE down pipe
CPE fuel pump
PCV plate (think its Kozmic? Was the OG one before MD or the other one came out)
Kozmic vented can and jbr sealed
Nice check valves for both of the cans
JBR rear mm and passenger side mm
CPE trans mount
Turbine tech front motor mount
4 AEM gauges in vent pods (blockhead triple and one in vent). Oil temp, oil pressure, water temp, manifold pressure
Sp63 fan controller
Corksport radiator
Corksport belly pan
Corksport front and rear sway bars. Rear bar has upgraded collars.
Front and rear bushing are poly.
Anti-lift kit installed.
Bilstein B8s on swift springs. Rear camber arms.
Oil/water heat exchanger that I may pull off. TBD on this line item.
TWM short shifter
Full size spare.
Absolutely nothing. I'm just being a jerk and teasing you.
I've thought about that aux heat exchanger a couple of times. I couldn't justify losing all that room, given all the other crap I already have.
I am excited to see another local do a build.
What CEL are you getting??
