steve@versatune
Lots of cool stuff in this release!
The update includes these changes:
General changes
Mazda 3/6/CX-5 SkyActiv Diesel
New tunes:
Mazda 3/6 MPS, Mazdaspeed 3/6 and Mazda CX-7
Mazda RX-8
General changes
- Support for importing and flashing encrypted and locked tunes from authorized e-tuners
- Preferred measurement units can now be individually customized both in the Tune Editor and in the Dashboard
- All fuel-related tables can now be displayed in either AFR or lambda units
- Improved usability when using the Tune Editor with the keyboard
- Improved performance when launching the app and working with tunes and logs
- It is now possible to search for tunes in "My tunes"
- It is now possible to import .vtlog format logs into the local database
- VersaTuner data folder can be quickly opened from the Settings screen for easy backup or migration to a different PC
New tunes:
- Base tune v1.06 with smooth boost and significantly improved power/torque
- Special tune to upgrade from 150 hp to 175 hp
- Tables that are different between 150 hp and 175 hp factory tunes
- Exhaust Pressure Limit constants
- Requested Boost Limit tables
- Injection Timing tables
- EGT Limit 1 and EGT Limit 2 tables
- Boost Limit BAT tables
- Added additional parameters to the General Performance logging preset
- Corrected scaling of exhaust gas temperature logging parameters
- Fixed Bluetooth logging issues
- Manifold absolute pressure dashboard parameter can now be customized by selecting the installed MAP sensor or entering custom calibration
- Boost pressure is now accurately displayed for aftermarket MAP sensors
- Added support for CorkSport 3.5 bar MAP sensor
- New logging parameters Catalyst Temperature and Fan Duty Cycle
Mazda RX-8
- Added new logging parameters Fan 1 and 2 Status and Fan 3 Status
- Actual Air Fuel Ratio can be logged in AFR units
- Corrected axis label for Oil Injection - Throttle 1 and 2
