teukka
Year/Make/Model: 2007 Mazdaspeed 6 (imported from U.S. -09)
Mileage: 103,000mi
Concern: Cylinder 2 misfire. Rough idle, but doesn't seem to misfire every cycle. Normal idle RPM. Very rough stuttering under acceleration, and blinking engine light (P0302). Engine light stays on after activation unless deleted. Cruising with constant rpm produces the same condition as idle (random misfiring, not every cycle). Starts up normal. FRP around 1600.
DTC's: P0302, cylinder 2 misfire
Modifications: none
ECU/Tuning Software: original
Tuner: -
Is the concern intermittent?: started intermittent, now constant
Can you duplicate the concern?: yes
Recent Repairs: new plugs after first DTC (NGK 3787, .031"), new coil (plug and coil also swapped between 3&2), compression tested good and equal on all cylinders, injectors cleaned + tested (resistance and flow), new Corksport injector seals, maf checked, replaced camshaft position sensor. Currently at the shop where they will check the PCM and exhaust sensor(?) on 9/13.
Correction: -
Might have forgot something from the list. Sorry for not having the exact details on everything or the freeze frame data right now, I don't have access to the car until 9/13. Please, if you have any idea lmk. Thank you.
Mileage: 103,000mi
Modifications: none
Tuner: -
Correction: -
