Akia Hawkins
I have a 2008 MS3 and im having a wild issue. It has a very choppy idle which causes stalling most of the time, and it has started randomly losing all accelerator pedal, as in I goto give it gas and it does nothing. Then when you pull over itll stall because its struggling to idle, and wont start back for anywhere between justa few minutes to an hour. (when it has issues starting back i noticed in the AP, KOEO, HPFP has 0PSI. Im on a base map from Will @PDTuning, hes saying check for vaccum/boost leaks, verify coil packs are good, and check grounds. The car has been smoke tested with no luck, im sprayed every vacuum line with starter fluid hoping to notice a difference in idle, but no luck. the car has spark. i can unplug each coil pack individually and notice a difference in idle. The car does doesnt throw any codes until 1. It Stalls at idle, itll throw a P300 code or 2. It stalls after losing accelerator pedal, itll throw a p2122.
Now i have an idle log, just recently the car wont go above 3600-3800 RPMS, the last couple times i drove the car the KR was maxing out at 8.00 around 2000-3000RPMs, im wondering if anyone could see if anything in the datalog is obviously off. The Plugs are NGK6510 gapped to 0.027 per Wills request. im wondering if its a injector issue as the car has 155k miles on it, is there anyway to verify it being an injector issue? Ive always heard, knock could be a sign of an injector issue.
Thanks in advanced.
Thanks in advanced.
