Since the real shenanigans don`t start until tonight (NAMM convention in Anaheim, if anyone was wondering), I figured I`d borrow a buddy`s Windows laptop and run some numbers. Can`t say I`m at all unhappy with these figures, and this is just the baseline. Once spring hits I`ll have a GTX2971R in here. I actually overshot my goal by a little, and the torque number just blew me away (not that I doubt it, it`ll keep the tires barking through 4th gear if I let it). The mods: JBR 3" WidePath intake, Autotech HPFP, CPe TMIC, Magnaflow CBE, 3" test pipe. Stock DP, stock K04, Stratified making it all dance to the same song on ethanol. I won`t take tthese numbers as gospel, but with a smoothing of 3 I bet they`re pretty close. Gonna put it on the for real rollers when I get back home next week.
Don`t really want to push it any harder, even though everything is just about perfect in the logs. IDC isn`t even hitting 100, LTFT is 0 at WOT (and generally about 3.5 at idle), and timing hit a max of 18*. As a curious side note, there was literally ZERO impeller shaft play in the turbo when I did the intake. Not a wiggle. Here`s to it kicking ass until I get the new turbo and methanol going :-D
