Dang, man; good thing you built. It looks like a windowed block was just a matter of time with that rod. Did you have any symptoms like the characteristic pulsing clutch as you depressed the pedal to let you know your rod was bent?Cylinder #1 went. Aside from this, the rest is fine. Ringlands are all fine, crank is fine, rod journals are fine. Even the cylinder walls are "fine", but with 111K on the odometer she`s getting the 88mm treatment regardless.
