Okay so update. Hope I don’t jinx myself but I turned the car on checked the plunger and it was extended. So I cleared the code and drive 30 minutes and the code hasn’t come back. That being said the only thing I’ve done to the system is cut the rod and flaps out itself(I cut the shaft just to before it enters the first valve port.) So this seems to work if you dont want to cover the extra vacuum holes. I was also talking to a buddy who’s done this on other cars that in theory if you cross the two wires at the solenoid. It should clear the code but the starter relay is the better option over the two and that should work as well as a last case option
