David Buckwalter
Looking for help diagnosing a weird issue with crazy fuel trims and a wandering AFR under light throttle. There is not an obvious vacuum leak causing this. This isn’t my daily anymore so it is not the end of the world but I am at my wits end trying to figure this out so I can work on my 6th port install and tuning.
Year/Make/Model: 2008 Speed 3
Mileage: Body:150,000 Engine:~60,000
Concern: AFRs are not hitting the target under light load, throttle, most commonly under cruising conditions and partial throttle, idle seems to have issue settling at 14.7 at random times as well. LTFT is generally around -10 and STFT is all over the place anywhere from -25 to +25. Logs are provided below. Also twice I have had the car start and be stuck at 9 AFR until shutting off and restarting or until letting it warm up. The car’s fuel economy is also absolutely trash now, it was never great but I maybe get 150-175 miles out of a full tank, I used to be able to get like 250 as long as I didn’t romp on it. There has been no additional engine/power mods on the car since the tunes were dialed in just regular maintenance and occasional repair.
DTC's: None related, one code for a dead heater circuit in the rear O2 sensor and the codes from my EGR delete.
Modifications: CPE TMIC, 3in highflow catted DP, 3in HKS Catback, TIAL VTA BOV, CS injector seals, Damond EGR Delete, HTP 3in intake, CST4, JBR intake manifold TIG, MAC valve, Autotech HPFP internals, NGK 6510 spark plugs, dialed street tunes for both e30 and 93 (issue observable on both), not really a mod but I did the timing chain 10K-ish miles ago.
ECU/Tuning Software: Cobb Accessport
Tuner: Andale927
Is the concern intermittent? Not really, the issue is observable to varying degrees every time the car is driven.
Diag already performed: Boost and vacuum leaks searched for and eliminated with pressure and smoke tests. Valves and injectors were cleaned and injector seals replaced. Spark plugs were replaced. I have tried both tunes and reset the ECU/ fuel trims for them multiple times. MAF connector was replaced. Reseated and checked on almost all electrical connectors in the engine bay. Purge solenoid valve was tested and confirmed working. Wastegate vacuum lines and MAC valve were checked. Oil cap seal was checked.
Datalogs: The CSVs are also uploaded
Idle: https://datazap.me/u/buckwdav/idle?log=0&data=3-15
2nd gear: https://datazap.me/u/buckwdav/2nd-gear?log=0&data=3-15
3rd gear: https://datazap.me/u/buckwdav/3rd-gear?log=0&data=3-15
Cruising and upshifting: https://datazap.me/u/buckwdav/cruising-and-upshifting-2-3-4?log=0&data=3-15
Tuner: Andale927
