Does the CS TMM insert really make a noticeable difference?Installed that GenPu mount and bracket then threw in the CS insert. Very nice...
I did notice it is more solid as I can now rev match downshift while in a turn more smoothly than before. I also did a few launches from a dig and just chirp tires instead of a little shake from the engine. Also going into gear is also easier. Bear in mind I also have the Damond SSP and CS Race RMM along with OEM PMM.Does the CS TMM insert really make a noticeable difference?
Did you install all motor mounts at the same time? Or did you get to install the CS TMM insert after the other mounts have already been installed?I did notice it is more solid as I can now rev match downshift while in a turn more smoothly than before. I also did a few launches from a dig and just chirp tires instead of a little shake from the engine. Also going into gear is also easier. Bear in mind I also have the Damond SSP and CS Race RMM along with OEM PMM.
[doublepost=1519748263][/doublepost]...also
I went in this order:Did you install all motor mounts at the same time? Or did you get to install the CS TMM insert after the other mounts have already been installed?
I previously had the DM RMM and it did everything you have described. Easier shifting, increased throttle response, less engine movement and more tire chirping. Unfortunately, it was a little too much NVH for my daily drive and so I went with the CPE stage 1 RMM. I was wondering how much of an improvement the CSS TMM insert makes when you already have an aftermarket RMM installed.
It is on my list of stuff to get for the car. Thanks for the feedback.I went in this order:
CS RMM
Used OEM GenJuan TMM & PMM
OEM GenPu TMM w/ CS Insert
So far it has made a big difference in the driving/shifting experience, coming from stock side mounts. You may experience more NVH than I can notice, only because it feels the same to me due to the CS RMM. I'd say get it. If you no likey, then take out the insert and rock the genpu mount.
Cool. I'm taking the mod path slow myself. No need to go full ham when I got nothing but time.It is on my list of stuff to get for the car. Thanks for the feedback.
Started overboosting without even going full WOT. Fun.
