Thats the proper ground wire. When you get a chance carefully resplice oem wire, its so small no loose wire/wires when you make a permanent connection. Just double checking, that you correctly attached the two small connections. One is small black noise suppression device thats on back side area of hpfp. Second is the hot water outlet -engine water temperature sensor.
