The time has come to finally get my built motor going after spending a year recovering from the previous machine shop fucking my block and sleeves and leaving me high and dry.
Parts on hand:
-2 spare short blocks with good cranks
-spare head
-Darton Dry Sleeves
-King TriMetal pMax black rod and main bearings
-Freektune H11 head studs
-ARP main studs
-Ecoboost oil pump
-all timing components
-Kelford 247-C camshafts
-Kelford 83lb valve springs
-oem valves
-Wiseco Custom 12.5:1 CR pistons with deep intake and exhaust valve reliefs
-H13 wrist pins w/ .250" walls
-Total Seal High tension piston rings paired to match my custom pistons
-Manley H Tuff + rods with 625+ rod bolts
-Massive Speed BSD plug
-Massive Speed Oil Pan baffle
-SP63 Billet Transfer Case Bearing Caps
-OEM rear main seal
-RamFab firewall master cylinder brace
In transit:
-Xclutch Ceramic Twin Disc rated for 1300 ftlb tq
Machine work to be completed
-Darton sleeves installed, bored and honed to 87.5mm 280 grit, 23* cross hatch
-block and head decked
-oringed block and head
Parts carrying over from my stock block setup:
-PTE 6266 GEN 1
-Cp-e vband exhaust manifold
-Kozmic DP
-CS CBE
-DTPFAB dump tube
-PTE PW46 EWG
-Tial Q BOV
-DWR modified fuel pump basket w/ TI automotive Hellcat 525 LPH pump and radium venturing (may be replaced with @Maisonvi
Version if he gets around to completing it any time soon)
-Aeromotive FPR
-BC Racing coilovers (rear springs will be upgraded to 700lb)
-Whiteline RSB
-CS Strut tower bar
-SURE rear diff mounts
-JMF w/ PI
Goal:
-Efficient power on lower boost with good transient response
Parts on hand:
-spare head
-Darton Dry Sleeves
-ARP main studs
-Ecoboost oil pump
-oem valves
-OEM rear main seal
In transit:
-PTE 6266 GEN 1
-Kozmic DP
-CS CBE
-DTPFAB dump tube
-PTE PW46 EWG
-Tial Q BOV
-Aeromotive FPR
-Whiteline RSB
-CS Strut tower bar
-JMF w/ PI
Goal:
